I am using a Fairphone 3+ for one year now.
I knew, that it had limited (older) Hardware, but in the past my FF3+ sometimes hangs for some seconds.
I have no idea, how to find the reason for the problems.
Is there somewhere a CPU usage (so I see the possible reason for the problems).
I have the Microsoft Launcher installed, because here I see at every app, that has new messages (like Signal) a counter of unread messages.
This is (as far as I can see) not possible in the default Launcher.
I got the same issue with my FP3 with updated front Camera. It seems like this has got worse since the last update to Android 11. I use the Nova Launcher and I have 12GB free space.
Whould be great to find a solution.
I also have the impression that it’s gotten worse with A11. My solution for this and other problems: reboot every few days, at the latest when something starts going wrong. Has always done the trick.
@IkarusFP3, @uodalricus and @OLLI_S (me) discovered performance issues after installing the Android 11 Update.
So this seems to be a “global” problem?
Or is the FF3+ to weak for Android 11?
@amoun I regularly clear my cache using the “Google Files” App.
And I also move my photos/videos to my external SD card.
I had no issues with my FP3 after the upgrade, in the meantime I installed Iode (also Android11) and the first few days it was a bit laggy, but now its running smooth. Even my FP2 was running most times good with Android 11, so I doubt the FP3(+) is too weak. Also I doubt its a global issue. Overall it depends as well a lot on your setup, Apps you use etc…
I found the reason for all those delays: Norton 360
After the Android 11 Update I also installed Norton 360 on my FF3+, because I am also using it on the desktop.
So I uninstalled Norton 360 to see, if this helps.
Now my FF3+ runs smooth!
