My Fairphone 3 is on Android 10 and the latest update is from 5 August 2020. With, without, or with a different sim installed, it does not receive any updates of a later date. A factory reset did not solve the issue. Could it be that the device is not registered at the update server. Does anyone has a suggestion? Thanks in advance, Otto
Thank you for your answers. I have tried to update via WiFi with the sim removed, but no avail. I updated to Android 10 manually, as under Android 9, the update process did not work either. Now it is about time I find the cause and hope that someone can assist me with finding a solution.
