Sorry I only need the exact model of the micro USB of the Fairphone 2 port so I can solder a new one that fits, I already tried and it didn’t fit.
Should be MC-XXX, but there are many to find it by sight.
Just marking @ElKrasso hoping he has an idea. ![]()
None of them.
The one that comes closest in my view is “MC-006”. It is not the used one in the bottom module, but the alignment of the shield and conector pins are the only left choice.
You need a very tapered solder tip to solder this by hand.
do you know a cheap place to ask for just 2 of them?
The cheapest for low volume is probably ebay.
