Fairphone 2 is dead
my fairphone bearly starts. Just one second (at the most) of the very first startup screen (you know with ‘Fairphone’ and ‘Powerd by Android’ in B/W) and some red flashes from the LED. Thats it, it stops and then tries again after a few second.
Anybody has any ideas?
Thank you all!
My son’s phone had the same symptoms, and it was a hardware issue with the motherboard :frowning:
Could the battery be flat?
Hi Dietmar.
Definitily not. But it is a train of thought. Maybe something on the motherboard makes the phone think it is. Electricity not flowing to the motherboard. Maybe even bad contacts.
I’ll have a look.
Thanks.
This is supposed to indicate a totally discharged battery.
See this support page, in particular on kickstarting the battery and possibly replacing the SIM.
