Fairphone 2: Crazy touch inputs (touchscreen issue) - workaround (for some): increase touch & hold delay
Well it is not fixed, it is improved.
Improvements to correct touch-screen over-sensitivity
(Changelog)
Let’s see how well the update worked:
Did updating 1.2.8 fix the issue for you?
  • Yes, I don’t have crazy touch inputs anymore.
  • No, I still have them
  • Not entirely. I still have them, but it is definitely improved
  • I have them now and didn’t before the update. At least not that many.
  • I never had the issue
0 voters
The same here, after the Update i can’t use my phone anymore. I wrote the support days ago but maybe I got to call Fairphone later …
In my case, I still can use my FP but there is still a misbehaving touchscreen. I am not quite sure if it is the issue discribed here, therefore I made a video of it: Video. If anyone told me how to paste it properly as a video (the upload did work for videos) I’ll fix that.
Most importantly: the bug didn’t get any better after the update. Maybe anyone knows why… If there is anyone else who still has the problem too, please reply so the issue is put on the list of known bugs again.
I still have the bug and have now been told by support I’ll get a replacement screen to try out when they are back in stock. No answer regarding when the spare screens will be back in stock though, except that it’s supposed to be “very soon”.
I wouldn’t get my hopes up about the issue ever being fixed in a software update. It seems clear to me now it’s a pretty common production defect which didn’t affect some owners who apparently have no problems. So I would recommend chasing support on the phone if your phone has the issue.
I just thought to do so. Has your issue any similarities to mine (see video link below)?
You can downgrade your device by yourself, if you want. Works a little bit like rooting because you have to flash the different parts of the OS, too. If you are interested in it, I could describe it more detailed.
My phone are going nuts, opening and closing apps v fast and unprompted. The only way I’ve been able to stop it is by removing the battery. When I switch back on it can be fine for a while b4 going crazy again, including making calls. I would have assumed this was a virus, but it is one of a number of issues I’m experiencing including parts of my screen not working and other issues mentioned on the forum.
Sounds like your touchscreen is going a bit beserk. I’ve moved your post here as it contains some tips that have helped improve the situation for others (see the first post for a summary). I also remember reading that removing and putting back the screen sometimes helps.
Thanks, I’ve completed the suggested fixes and it is behaving, for now. Part of my screen is still not responsive. I checked on a drawing app to test and the area is at the bottom of the screen in the middle. when texting in portrait I can’t use y,g,h,v,b or part of the spacebar. is this a hardware issue?
I’m afraid it is a hardware issue. See here for mor info:
Thanks for your help.
Hello People!
I have the problem too, i mean the ghost multitouch issue.
I also have a dead zone on the lcd.- if i put the finger on it, it makes two inputs like on the picture.
I cant use my phone anymore.- I have sent a support mail and got a ticket number .
It is definitly a hardware problem.- i set the option for “show the touch input” in a problemfree minute. (doesnt know how it is called in english android, but you understand, right?)
:slight_smile:
I tried to clean the screen best i can, short time it was better but not the yellow from the egg.
What shall i do? Calling the support on my cost?
Thank you well!
Greets from Austria,
Chris
Looks mainly like this issue:
(In short: For some people removing and reassembling the screen solves the issue.)
Somtimes (but quite often) the touchscreen of the FP2 gets into chaos-mode and delivers erratic positions. I switched on “Entwickleroptionen → Zeigerposition” (“Developer options → Pointer position” ?). In this mode it displays crosshairs at the pointer-position and draws a graph of the movement.
I moved the finger slowly horizontally, but as you can easily see the movement in y-direction jumps around totally erratic. Apps that require scrolling, zooming etc. are nearly unusable in this state.
I experience this behaviour at about half time of usage, possibly connected to the charging-state of the phone.
The problem exists since the first day, my hope that it will be fixed in the first software-update was deceived.
Update: still exists in 1.3.6.
did you try cleaning the screen? I found my FP2 works a lot better if I take the cover off and clean around the edge of the touch screen and around the inside edge of the rubber bumper. I have a theory that crap gets stuck between the cover and the screen and gives it false inputs (ie like when you get drops of water on the touch screen).
Worth a try anyway.
Hey Chris, sorry to hear your FP2 is experiencing these issues. I’m not sure if anyone from our team has been in touch yet, can you give me the 6-digit request number of the message you sent us? Thanks in advance. Michiel
I’ve got the same issue. If I touch the “e” on the keyboard it selects “w” and “r” - this alone makes my phone unusable. Additionaly to this my phone runs crazy with swiping and tapping randomly. Please fix this asap.
Could any official say something about that issue, please? Is there any sense in writing a ticket? I hope enough people already did this.
Thank you very much in advance.
- protux.
PS:
  • I tried the fix above - with no result
  • I booted into recovery mode and cleared the cache - with no result
    Please help… :confused:
Thank you Michiel, i have got a submit from support. I already created my account at return portal and be waiting to send the phone back.
Why do we need 3 Accounts for Fairphone-shopping, Zendesk AND Return=? does something go wrong?
Is there any idea that 1.3.6 makes this worse? It has for me so far
I think so, too. Before 1.3.6 I had this issue just while loading the phone, and shortly after the patch my phone went crazy…
