Hi everyone!
I’ve just replaced the bottom module on my FP 2 - as I thought a fault with it was the reason for the lack of connectivity between cable + charging port (had to hold it for it to connect).
This was after replacing the battery - as I had thought the difficulty charging might be due to a run down battery.
Now I’ve replaced both bottom module + battery, however it is taking quite some time to load. And it is not progressing past the lowest bar of the battery - even hours on.
I also noticed that the phone is very hot.
Do you have any ideas what might be wrong with the phone? And if there is a solution to fix it?
Thanks very much for your help! Hoping to revive it
Lucy
