Good evening, unfortunately, the camera of my Fairphone2 does not open any more. Tried everything incl. update and empty cache (“Kamera wird wiederholt beendet”, App Informationen, App schließen). Any ideas?
I am located in the South of Germany near Switzerland.
Did you try cleaning the contacts of the camera module? Or do you possibly even have the possibility to change it with a working module of someone else?
It might be a problem with the module.
Thanks to you John, very kind and lots of options I will try out.
I have read that somebody in the community suggested using “open camera” instead. I installed this app this morning and it works very well, so whilst I will try to “repare” the camera, I am not left without the camera option.
Good suggestion as well and very self-explanatory, the open camera.
All the best,
Steffi
