The blobs need to be copied before starting a build of the full system.
I know that. But the normal users will not be able offer to so much cpu power and space to compile/download ~60-70G of code just to build a ROM for their phones. And the final build cannot be shared otherwise, or? Or do you want FP to offer the download for the CM rom?
First of all, there needs to be someone whoās able to produce a bootable image. If this is achieved, there will still be a lot of work to make this image usable. As I said before, Iām not a CM-dev, but I guess, depending on how many people are working together, this can take up to a few months. Until this point it doesnāt make sense for a ānormal userā to install these images anyway.
If the port gets into a usable state it is possible to submit it as an official CM port. Once it gets accepted, the images will get hosted by CM and get published on the download page.
I donāt know if they are acting in a legal gray area, but apparently they are hosting the imagesā¦
But unfortunately the hard work needs to be done first, before discussing the possibility where to download the result.
Edit:
Out of curiosity I wanted to check whether the images from the CM download page contain blobs or not. They do! You can download a python script from github to access the file system of the images. The latest M8 image for example contains the files listed in common-proprietary-files.txt, linked in my previous post.
Did you try to build an image of Cyanogenmod for the Fairphone 2?
Or someone else?
Just trying to revive the thread, Juan Gomez (atilag) from Mozilla did a blobfree Firefox OS (B2G) compilation for the FP2 which extracts blobs from the device before packing the fastboot images.
Due to the similarities between the build processes of CyanogenMod and B2G, because they share the same low level base of Android, I think a port of CM to the FP2 is viable, with the B2G port as an example.
The FP2 configs for B2G are here: https://github.com/mozilla-b2g/device-fairphone2
The list of blob-files needed are here (from FP2-1.2.8-gms, if I recall right): https://github.com/mozilla-b2g/device-fairphone2/blob/master/proprietary-files.txt
Now we have some right things to continue the @keesjās initial work on the CM12 port. My machine is pretty slow, but, damned, I prefer having it burned down than not trying anything!
Edit: CM Recovery successfully compiled,
Edit2: flashed. It works, yay!
Edit3: Iāve done a new extract-files.sh that seems to extract blobs, at least. Iām kind of improvising⦠never cooked roms before. See it here.
Edit4: I tried a full CM12 build today. Failed, of course, a lot of things have to be adjusted. I talked with Juan (I know him from some Mozilla meetups, and he has experience with CM ports) for generating an up-to-date blob-list. This is going to be funny, but slow. Should someone wants to help, message me,
This last post should be in:
/Software/Developing/B2G beta (formerly Firefox OS)
Could any mod shift it?
My post? I donāt think it should. I could have explained myself bad, but Iām trying to build CyanogenMod, not B2G. The FxOS/B2G mention is because it is based on (the low level layer of) Android and both build processes have similarities (one being the blob dependencies to fully work).
I hope more peple who are able to work on a CM port will help you and push it further. I donāt want to lose CM when switching to a FP2, so I rely on guys like you and I want to thank you for your initial work here.
OK, my fault! The missing words were: āwith this knowledge we can try to built CMā
You are right! I missed that words,
Edit: I edited that post. Hope itās more clear now.
Iām stuck with this error:
JarJar: /home/debian/Workspace/fairphone/cm12_fp2/out/target/common/obj/JAVA_LIBRARIES/conscrypt_intermediates/classes-jarjar.jar
host SharedLib: libjavacrypto_32 (/home/debian/Workspace/fairphone/cm12_fp2/out/host/linux-x86/obj32/lib/libjavacrypto.so)
target SharedLib: libandroid_runtime (/home/debian/Workspace/fairphone/cm12_fp2/out/target/product/FP2/obj/SHARED_LIBRARIES/libandroid_runtime_intermediates/LINKED/libandroid_runtime.so)
target Symbolic: bluetooth.default (/home/debian/Workspace/fairphone/cm12_fp2/out/target/product/FP2/symbols/system/lib/hw/bluetooth.default.so)
frameworks/base/core/jni/android_view_Surface.cpp:404: error: undefined reference to 'android::uirenderer::AnimationContext::AnimationContext(android::uirenderer::renderthread::TimeLord&)'
frameworks/base/core/jni/android_view_Surface.cpp:431: error: undefined reference to 'android::uirenderer::renderthread::RenderProxy::syncAndDrawFrame(long long, long long, float)'
frameworks/base/core/jni/android_view_Surface.cpp:425: error: undefined reference to 'android::uirenderer::renderthread::RenderProxy::updateSurface(android::sp<ANativeWindow> const&)'
frameworks/base/core/jni/android_view_Surface.cpp:412: error: undefined reference to 'android::uirenderer::renderthread::RenderProxy::RenderProxy(bool, android::uirenderer::RenderNode*, android::uirenderer::IContextFactory*)'
frameworks/base/core/jni/android_view_Surface.cpp:413: error: undefined reference to 'android::uirenderer::renderthread::RenderProxy::loadSystemProperties()'
frameworks/base/core/jni/android_view_Surface.cpp:414: error: undefined reference to 'android::uirenderer::renderthread::RenderProxy::setSwapBehavior(android::uirenderer::renderthread::SwapBehavior)'
frameworks/base/core/jni/android_view_Surface.cpp:415: error: undefined reference to 'android::uirenderer::renderthread::RenderProxy::initialize(android::sp<ANativeWindow> const&)'
frameworks/base/core/jni/android_view_Surface.cpp:418: error: undefined reference to 'android::uirenderer::renderthread::RenderProxy::setup(int, int, android::uirenderer::Vector3 const&, float, unsigned char, unsigned char)'
frameworks/base/core/jni/android/graphics/Paint.cpp:809: error: undefined reference to 'android::uirenderer::Blur::convertRadiusToSigma(float)'
collect2: error: ld returned 1 exit status
build/core/shared_library_internal.mk:68: recipe for target '/home/debian/Workspace/fairphone/cm12_fp2/out/target/product/FP2/obj/SHARED_LIBRARIES/libandroid_runtime_intermediates/LINKED/libandroid_runtime.so' failed
make: *** [/home/debian/Workspace/fairphone/cm12_fp2/out/target/product/FP2/obj/SHARED_LIBRARIES/libandroid_runtime_intermediates/LINKED/libandroid_runtime.so] Error 1
make: *** Waiting for unfinished jobs....
make: Leaving directory '/home/debian/Workspace/fairphone/cm12_fp2'
#### make failed to build some targets (09:40 (mm:ss)) ####
I honestly donāt know whereās the error. Any ideas to try?
wow! that is the best news i heard since FP2 came out! soooo nice to see, finally it is ging on! keep it up!
Were you able to progress after that error? Iām no Android or Java coder at all :-/.
Linkage errors are really hard to debugā¦
Best scenario, you just missed a compilation flag on the command line, or you donāt use the correct compiler.
If not, then⦠go on the code and try to understand why it is not working⦠But with this kind of code, itās seems pretty hard.
BTW I am really interested to help building a CM image, but I donāt really have lots of time and I never cooked roms. I will try to dive into this topic and free 50Go on my Debian
Not yet, Iāve been a little busy this week.
[quote=āNicoM, post:70, topic:10399ā]
Linkage errors are really hard to debugā¦Best scenario, you just missed a compilation flag on the command line, or you donāt use the correct compiler.If not, then⦠go on the code and try to understand why it is not working⦠But with this kind of code, itās seems pretty hard.[/quote]
Iām using CMās mka for avoid that kind of things.
Iāve not much experience with big builds nor C/C++ matters. Iām on Debian Testing, but seems like Iāll need to move to Ubuntu for this⦠which means Iāll have to set up a VM and compile time will increase, ![]()
Me neither! Hahaha. Come and help, Iāll appreciate it, ![]()
Maybe someone can wiki-fy the first article and add an up to date howto (what to checkout, how much space will be needed ⦠) and current problems, so that more people will try it? Most stuff can be copied from the old howto, I assume.
Good idea as a restart :).
Issue solved!
Just enabling OpenGL solved it
Prety cool, so youāve got a working CM build now?
Well, this is a rather slow process. CM successfully building is not equal to CM successfully booting (yet),
. But, obviously, it is the first step,
