Fairbuds XL (2025) no cushion twist
Ive seen a few comment scattered on Reddit and YouTube bout this but nothing seemingly here, the ear cushions on my fairbuds xl simply do not twist and pull off, I have tried everything but ripping them destructively, I have even tried matching my grip to the ones in their repair videos, nothing, not a creack or a click, someone on reddit said they’ve had better success with warming the cups with a hairdryer stating that there could be an issue with glue somehow causing this, but I have yet to do that as I dont NEED them to come off, I just want them to as they should just be able to. But I get nothing, they are firmly locked up tight. Anyone have amy secret hand placement or techniques that i am just missing
You will probably already be aware of this, but anyway:
The part to remove is really just the cushion covered by mesh fabric and no visible plastic. I strongly suggest to focus your physical energy on the widest and hard part of the cushions: There is an invisible, vaguely disc-style hard part inside there, right next to the small seam/gap between the visible plastic of the speaker and the soft mesh of the cushion.
Other than that, the direction to unscrew the cushion from the speaker is counter-clockwise – which the video already suggests by instructing to unscrew the right speaker’s cushion away from you (assuming the right speaker is to your right and the left speaker to your left).
Last but not least, when it works, the unscrewing should only move the cushion little more than 0.5 centimetres (I guess that translates into 1/5 of an inch) – it should be possible to just lift it off then.
Now, I guess you were already aware of and tried these things. So you might need to contact Support in time, even when it’s just “pre-emptively”. At least do so before your warranty expires.
On my older Fairbuds XL it was hard and I teared the fake leather a bit. Putting new fabric cushions in was easy. I think the trick was just pure desperation after tearing the fake leather anyway, so I knew it have to came off.
On my Fairbuds XL 2025 I tried but I couldnt manage to remove them. I didnt try as hard as with the older since, since as you I dont need it… yet :slight_smile:
Contaced Fairphone support this was their responce.
Usually, this works well, and I have not heard of other customers reporting the same issue. If you need to remove the ear cushions in the future, we can arrange for your Fairbuds XL to be sent to our repair centre, where our repair technician can safely remove and replace them. For now, this is the solution I can offer.
If you have any questions, let us know and I’ll be happy to help you further.
I just wanted to add that my cushions after breaking the glue arent loose / I didnt notice any disadvantage. I wonder why they use the glue at all. I know why one would use glue on screws but here it makes no sense..
After first struggle and breaking the glue loose I just hold the plastic right behind the cushion and twist.
I didnt report this as an issue, but if you want, you can tell them that owner of both older and newer fairbuds xl 100% had and have problems with the glue :slight_smile:
