Fairbuds for running?
Has anyone been doing it? Need to replace my Shockz, and I’m curious in terms of fit and transparency mode in particular.
Heyhey
I run with them, I have no issue to report :slight_smile:
Thats a firm copy. You have some sort of transparency mode? I Loke the safety of my bone-conductors :blush:
I guess what you mean is called “Ambient Sound (Voice through)” on the Fairbuds, see here (scroll down a bit): https://support.fairphone.com/hc/en-us/articles/17070751145746-How-to-use-your-Fairbuds#controls
Would most def seem so! Has anyone tested this? :blush:
I usually use noise cancellation when running, ambient mode is good but since it’s windy over here it tends to be too noisy for me
