I went for a run with my brand new Fairbuds and they kept crashing every 5 minutes or so (most of the time with a loud cracking sound in the speakers).
Putting them back in the box allowed to restart them. Anyone else has encountered this?
Hi and welcome.
I opened a topic for you. Could you add if you use the Fairbuds with an iOS or Android device and if you already have the most recent firmware v5.6?
Hey,
Sorry, I wasn’t sure I should create a new topic
I didn’t had the 5.6 firmware update yesterday when using the app, I’m doing it right away. I’m on Android.
This was only happening when connected to my Garmin smartwatch, not my phone nor laptop. I’m not sure I won’t be able to test it anytime soon with my watch.
EDIT: I can’t do the firmware update, the app stays stuck at 1% downloading for 15 seconds then I’m told it has failed. I reset the app without more success. Maybe I’ll wait for an app update? I’m on 2.0 without update in Play Store.
Seems you didnt see the most recent version yet
I’ve had this happen on the latest firmware on my steamdeck, it might’ve been an one off thing so I’ll keep this updated if it occurs again
Hi, even on the newest firmware, I have the same issue with my Garmin Epix Watch. Will this be fixed soon? Because otherwise I will need to return them.
So I did a simple test:
It seems we are at least two that have the issues with a Garmin smartwatch, one with a Steam Deck, maybe a pattern when it is not a regular smartphone/laptop?
In case it helps, my watch is a Forerunner 255S Music. Last buds firmware of course.
Did you contactsupport ? This would at least increase the probability of a fix.
Hi, there
I have the same problem with my fairbuds and the garmin forerunner 265. After 5min, the fairbuds switch off playing the shutdown jingle. I can then switch them on by long-pressing on each bud, but they keep crashing down.
I did not have such a problem with my old earbuds and the watch.
I would be interested, whether you guys could fix the problem and if yes, how?
Cheers, Irina
That sounds similar. Def report to Fairphone support
Hi, same issue with forerunner 245. We tried on two devices (both forerunner 245)same result. It crashes every 5min or so and can be restarted, but that’s really unnecessary while on a run. After I updated the firmware I thought it would be fixed as I thought it to be working with my device, but then it returned. Since it’s likely a software bug I hope it’s getting fixed or I need to return them… Music while running is our main use case.
@Hennu did you try the settings mentioned in the post before yours?
The latest update, v65, seems to have fixed the issue. I was able to use my Fairbuds on my Garmin Forerunner for more than 30 minutes.
Nope, it has not
it worked for a few runs, but the same issue started again yesterday.
Same for me. Thought it worked now until again it didn’t.
I have the same issue with iphone 13 mini, ipad mini, and nintendo switch.
I would be happy if they fix this bug, it still does this with my fairbuds and Fenix 7Xpro solar…
I also have this Problem. Garmin Fenix7. This is the only use case for my fairbuds. So right now they are pretty much completely useless.
