Any tips where I can get one for my FP1? Got tired oft deliting files. The internal storage is too small. At the same time, buying a Samsung vor scandisc SD feels like a double standard…
I have never heard of something like that. You’ll probably have to buy a standard microSD card. As far as I can imagine, most of the work in an SD card is done by machines though so that shouldn’t be too much of a problem fair-wage wise.
EDIT: If you want to buy a most sustainable SD/microSD card choose the one with the lightest packaging and buy it in a local store so the environmental impact of you purchase stays as low as possible.
Thank you for this comforting answer. Good to know that there is only a little room for labor issues. I think i’d try to find a manufacturer with an acceptable ecological Reputation.
