I use FP Open OS - and just moved to Release 16.07. Before the update, I had moved F-Droid to a system app. After the update it was gone. I didn’t realise this until agter the update. I then downloaded the app. In the meantime I had installed XPrivacy (still a noob and don’t understand everything…) and gave F-Droid rights. Afterwards (this is probably the problem) I moved it to a system app again.
Now F-Droid cannot connect to the internet (probably because of XPrivacy), but I don’t find the app in there anymore.
Question: How do I move F-Droid back to a “non-system” app? Do my installed apps then reapper in F-Droid. At the moment it says no apps.
Thanks
You can try to install /system/app mover (you can download the APK in the bottom of the page) or Titanium Backup, the both have the capability to move apps from system to user partition and vice-versa (be careful with REAL SYSTEM APPS!!!)
Bye!
Thanks to @DjDas I moved the system-F-Droid back to normal-F-Droid and changed the XPrivacy settings.
