Experience with LineageOS
Continuing the discussion from TWRP for Fairphone 5:
Not much of an expert here since I’m an os Rom newbie myself but it seems that lineage has frequent updates and is not too far from the stock os. I’d judge them to be fairly comparable, even if my experience with lineage has been just a tad more buggy than the fp os. If you choose to keep your bootloader unlocked like I did it may be a bit of an extra risk to take security wise.
I also chose to play it safe and use the gapps mod to keep my access to the play store,also stock find my android. Something to consider with microg.
@SpidFightFR please keep the discussion reg experience seperated from the TWRP topic. I opened a new topic for you
I’m using LOS since I bought my FP3. Very few issue so far. It is my daily driver, and works like a charm.
I had a FP 2 for 3 years running LineageOS 18.1. For 1 year now, I have a FP 4 running Lineage 22.1. For each of these 2 phones, I didn’t install MicroG and I did the weekly updates and I never had the slightest bug, everything always worked perfectly.
The only ā€œdrawbackā€ of Lineage that I recognize is the fact that after flashing the rom, it’s impossible to lock the bootloader.
Hi there, had my fairphone 5 for about one month, but the first thing I did when unpacking it was checking if it worked and then I unlocked it and installed Lineage.
My primary reason is, that I dont want to use Google services, so I flashed microG for some compatibility and Magisk for my root.
It works absolutely fine, I currently know about two bugs:
If you enable the charge percentage limiter your phone charges quite slowly, if you don’t need that feature everything is well.
The other problem is, that if you don’t boot your phone with a charger attached double tap to wake your screen doesn’t work.
Those are really not an issue for 98% of people, so I’d bet you’re fine. Also these issues have been already reported.
Out of curiosity (I hope it’s not off-topic here), are all these settings (like limit battery to 80%, and slow charging) available on LineageOS, or are some of these ā€œFairphone exclusiveā€?
Since I stopped running custom ROMs I’m not very educated in what’s part of stock Android and what is specific to manufacturers. I really like the slow charging setting (although I wish Fairphone would (also) have adaptive charging based on the alarm clock) so I’m interested to hear if LineageOS has more, less or the same options. :slight_smile:
You can limit charging to 80% and use ā€œeco chargingā€ in FPOS. I don’t use the limit to 80% so i cant tell if that causes issues in this too or just with LineageOS
LineageOS usually tries to deliver a bare android experience. They only add some minor features, like their profile system, that allows for some minor automation or the seedvault backup solution. You can get all of that with different apps if you wanted.
If you need additional features people usually go to roms like crdroid, though I’m pretty sure that is currently not available for our phones. Maybe a universal GSI rom.
For me personally I would have been fine, even with fairphone os, wouldn’t have been on the ā€˜bleeding edge’ with android versions there, but in the end my goal with custom roms is the Google free experience, so I need a rom without gapps pre-installed.
I waited for los to be released before buying my FP3 and I have been using it since then (with gapps). From time to time, there are bugs, but never really critical ones.
I am very happy with it. The security updates are usually much faster than with the FPOS.
I can only recommend it.
Oh, and I am in Android 15 already…
For me, the charge limiter works perfectly on LOS (I have fast charge and generally, I don’t experience the issues describe by @Janik ).
Thank you! Sounds nice, I will consider migrating when I want faster Android versions again, or if I’m ready to make the no-gapps leap :sweat_smile: I’ve got to say that the experience of Google-less people here sound very positive!
P.S. does anyone know why my posts don’t get the little ā€œreply toā€ icon like @autra’s above has? I keep selecting ā€œlink reply to postā€. Ah – or is it only when there are other messages in between?
Which reply sign do you mean? The circled one or the blue one?
Exactly. That’s the reason (and there’s also not that icon in case of quotes like mine now :wink: ).
Neither, I meant the little icon signifying that your post is a reply to an earlier post — @Volker answered my question, and it makes a lot of sense :smile:
(so I now understand that this message will get the reply label, since Volker’s message is in between)
