Hello everyone!
I recently got an FP3+ with /e/OS, which I started using on the 27th December, and ever since the beginning I’ve been having issues with the battery.
First, I had a battery drain problem, which I think I have now solved after tweaking the settings.
Then, I’ve noticed that the phone suddenly switches off with no warning when the battery gets down to around 10% of charge. The light keeps blinking for a while but I can’t switch the phone on: I need to plug it and the phone needs to start charging for me to be able to switch it on.
And now comes the weirdest thing: every time I’ve had to physically remove the battery and put it back in for the phone to start charging. Otherwise it will not start charging at all when I plug the charger.
I found a couple of old posts by people complaining of a similar behaviour on FP1 and FP2, and they solved it by getting a new battery. But I’m asking here first because I’m using the newest FP3+ and because my battery is not even two weeks old yet.
Does any of you have an idea of what could be causing this issue and how I could solve it?
Many thanks in advance!
descripción en español
Hola a todos.
Tengo un FP3+ con /e/OS desde el 27 de diciembre pasado, y desde el primer momento he tenido problemas con la baterĂa.
Al principio, la baterĂa duraba alrededor de un dĂa aunque yo apenas usara el telĂ©fono, pero creo que ya he resuelto este problema tras activar el “Develope mode” y ajustar la configuraciĂłn.
TambiĂ©n resulta que el telĂ©fono se apaga de repente y sin avisar cuando la baterĂa llega a alrededor del 10% de carga. La luz sigue parpadeando durante un tiempo pero no puedo encender el telĂ©fono: tengo que enchufar el cargador a la electricidad y que el telĂ©fono empiece a cargarse para poder encenderlo.
Y ahora viene lo más extraño: para que el telĂ©fono empiece a cargarse, he tenido que quitar la baterĂa fĂsicamente y volver a ponerla cada vez; si no lo hago asĂ, el telĂ©fono no empieza a cargarse aunque enchufe el cargador.
He encontrado un par de antiguas entradas en foros donde habĂa quienes comentaba un problema similar en el FP1 y el FP2, y lo resolvieron comprando una baterĂa nueva. Yo pregunto aquĂ primero porque mi FP3+ y su baterĂa tienen apenas dos semanas de vida.
ÂżAlguno tiene una idea sobre lo que podrĂa estar causando este problema y cĂłmo resolverlo?
¡Muchas gracias de antemano!
description en français
Bonjour !
J’ai un nouveau FP3+ avec /e/OS depuis le 27 décembre dernier, et depuis le premier moment j’ai des problèmes avec la batterie.
Au début, la batterie durait environ une journée, même si j’utilisais à peine le téléphone ; mais je pense avoir résolu ce problème après avoir activé le “Developer mode” et ajusté les paramètres.
Il arrive aussi que le téléphone s’éteigne soudainement et sans préavis lorsque la batterie atteint environ 10 % de charge. La lumière continue de clignoter pendant un certain temps mais je ne peux pas allumer le téléphone : je dois brancher le chargeur et faire en sorte que le téléphone commence à se charger pour l’allumer.
Et voici ce qui est le plus étrange : pour que le téléphone commence à se charger, j’ai dû retirer physiquement la batterie et la remettre en place à chaque fois ; si je ne le fais pas, le téléphone ne commence pas à se charger même si je branche le chargeur.
J’ai trouvé quelques vieux messages sur des forums où des gens commentaient un problème similaire sur les FP1 et FP2, et ils l’ont résolu en achetant une nouvelle batterie. Mais je pose d’abord la question ici car mon FP3+ et sa batterie n’ont que deux semaines…
Quelqu’un a une idée de ce qui pourrait causer ce problème et de la manière de le résoudre ?
Merci beaucoup d’avance !
