Enable volume button keys to activate/deactivate do not disturb mode
Is there a way to make the volume button keys have the functionality to activate/deactivate do not disturb mode? My previous android phone had this feature and I really like it.
If you do not know what I mean, here it is shown on the Pixel.
However, I couldn’t find the option in the FP3.
If you hold down the power on button and the volume down button at the same time, you can activate the vibration mode or muting the phone.
To configure it you can go to:
Settings -> Sound -> shortcut to prevent the device from sounding (I don’t know if this is the actual menu name, since I’m translating it from my language)
It’s not the same as you ask, but it might help :slight_smile:
