I really like this feature that I used a lot on my previous phones, enabling to pay quickly with just a long press on power menu. That option seems to be absent from FP4, anyone has an idea if there’s a mod to enable it ?
Found this but it seems quite outdated and only relevant for Google Pixel devices
It works without pressing a button, like just putting my unlocked phone on top of a paiement terminal ?
If so, did not know that, never tried ! Always assumed you had to open Pay app or the Wallet feature on power menu.
Anyway, how does it behave if you’ve got like 3 different credit cards ? I would not want any “default” credit card automatically selected when putting the phone on a terminal.
The Power Menu (sadly) no longer exists on Android 12, Google removed it. Similar features are now available when dragging down from the top of your screen.
It’s also available on my wife’s Google Pixel. I really think it’s a standard android 11 feature.
That’s why I wondered if there weren’t some magisk mod maybe to add it ?
I had issues using Google Pay on my Fairphone 4. I am used to just putting my unlocked phone on the terminal without any open apps. Any chance to let my phone behave similarly?
I have the same problem on my FP4 running the Android 11 that came with the phone. I can only pay with Google Pay by opening the app and tapping on my card.
For comparison, on my previous phone, a Nokia 8.1 also running fairly stock Android 11, I could use Google Pay any time the phone was awake, including on the home screen. The Nokia also had the card picker in the power button menu, which is also missing on my FP4.
