Hi, after updating to Android 14, suddenly my ear speaker is not working any more. I can only make calls with the loudspeaker on.
Anyone knows how I can possibly fix this?
Best wishes
I have the same problems as you… Sometimes a restart helps.
I even have the problem that the speaker sometimes just stops playing sound. A restart helps there, too.
From my point of view, these are all software problems and unfortunately they are extremely annoying.
Hi ksk,
I very hope, that you found a solution. I do have exactly the same problem. What have you done?
Thanks
