Hi
I want to install DotOS(v2.5 preferred) on my FP3 but I couldn’t find anything about this topic on the internet. I’d prefer to use TWRP Recovery, but it isn’t a must-have.
Thanks for your Help🙂
Hi
An internet search for dotos leads to https://www.droidontime.com/ … which has a link to https://www.droidontime.com/devices … which doesn’t list the Fairphone 3/3+ as supported … but back on https://www.droidontime.com/ it has “Frequently asked questions”, among them …
"Q: My device is not supported! What should I do?!
A: First reason can be that our development team doesn’t have your device to support it or we no maintainer applied for this device. You can always use our GSI builds if your phone supports Treble Project."
… so, back to https://www.droidontime.com/devices, and indeed it has a link to “GSI (Universal Builds)” with the choice of A64/ ARM/ ARM64 … an internet search for this leads to https://android.stackexchange.com/questions/218769/what-is-the-differences-between-rr-images-arm-a64-arm64-system, which says …
“If you are installing GSIs and you want to know what type of GSI to choose then install an app called ‘Treble Info’ from the play store.”
… which should then help with the question of which file to download once the corresponding choice of A64/ ARM/ ARM64 is made at https://www.droidontime.com/devices - GSI (Universal Builds).
As for how to install … an internet search for install gsi brings up https://www.xda-developers.com/flash-generic-system-image-project-treble-device/.
Thanks😁. And no, I meant 2.5, Ilike the old UI much better than the new.
Ah … Android 8, September 2018 security patches … I see, an enthusiast for the UI and a refined collection of assorted security holes .
Well, 5.2 isn’t that much better: release date October 2021…
But no problem, you are safe, their FAQ says:
Q: Is dotOS safe?
A: Firstly you’re unlocking bootloader which is opting to lose security features from OEM [Manufactures]. if that’s not your concern, rest assured you’re totally safe. we have covered all security patches released by google and several security enhancements to keep you protected.
… unless you choose the GSI, which currently we didn’t update for a year and change. But we will not say that out loud .
Oh, and I forgot …
GSIs may work nicely as a daily driver on a device, or they may not, it’s not their main purpose.
The developers have probably abandoned the project and it is no longer maintained, right?
It doesn’t look entirely dead. They have 6.0 beta versions out for some supported devices dated September 2022 at least.
