Hi there,
Apart from one exception with huge problems, OTA never worked on my rooted device. fixing-ota-after-rooting didn´t work out.
so naively I hope installing FP OS manually removed my root. Is this correct?
I followed this guide and now I am on latest Android 12 FP OS:
“Installing Fairphone OS Manually” (https://support.fairphone.com/hc/en-us/articles/18896094650513)
I tried to switch to Iodé4 which failed twice. (another odyssee of a huge set of problems, hopefully solved)
I am wondering, whether unclean root removal may be the cause.
Anyway, I want to switch to Iodé3, not 4.
thanks in advance!
Was critical unlocked what is not requested for Iode as far as I know? No idea if this can cause issues.
Thats outdated and no longer maintained, I guess you are aware.
To unroot isnt there instructions on the offiical magisk page?
thanks, yvmuell,
- install FP OS critical unlocked: yes, then followed instruction for locking.
- first try Install Iodé4 critical unlocked: no and no reason for failing was mentioned.
- second try Iodé message on screen was, it needs critical unlock - which is the contrary to instructions.
I had a lot of mess with unlock ability. finally managed to get it back to 1.
(thanks to all, who posted the solution)
Yes, I know, however 18 months w/o OTA wasn´t sensible, too:)
An hour ago, indeed I found one there via ADB.
so far, my Iodé3 is flashed w/o any problems.
