Does anyone know if the Fairphone 3 runs 64-bit android?
Please note, I’m not talking about the processor or anything else, just the actual Android OS.
I need to know this for an app which annoyingly only works on 64-bit android.
Thanks.
I’m not 100% sure how to best check that. I executed uname -a in termux to get the kernel architecture and that is “aarch64”. Sounds like 64bit to me.
Maybe easiest would be if you could name the app and we can check if the play store offers that for install (then obviously being compatible).
Oh yeah, that’s a lot simpler, heh, the app is ‘Chase UK’, thanks
It’s installable for me, so I guess all should be fine :slight_smile:
