"Do not disturb" mode
Hi there,
I got this issue for about one day or two and it’s quite annoying.
When the mode “Do not disturb” is on, it usually works normally, but these days it simply doesn’t work at all : some applications that are not in my priorities ones still ring and make noise.
I hope you can save me with this mindtroubling issue !!
Thanks :slight_smile:
No one else has got this problem ? :frowning:
Have you tried to change the mode? Or put these apps in the “priority” list, then remove them?
I don’t have apps in my priority list and don’t experience such problems.
Maybe you tell us some example apps and I try it on my phone. What OS and version do you use?
Well I only got a few in that list like Android messages…
