since few days incoming calls don’t vibrate anymore on do not disturb more, only silent.
How can I fix that?
I want to get vibration for incoming calls and nothing else please. as it was in the past.
Have you checked on your “do not disturb” settings in settings->sound¬ification->do not disturb?
Also have a look if maybe there are any automatic rules active for this behavior.
yes thanks and there isn’t. is there any way to let only vibrate for incoming calls and not for all other notifications as I used to have?
For me Do Not Disturb went completely broken a while back. Not sure exactly when, I suppose since the update from January or some kind of Google update. It is a useless feature ever since.
