DIY: Customizing my Fairphone 6 case with Rit Dye (Cognac/ Terracotta result) [GUIDE]
Hi everyone!
Today I’d like to share a DIY tip for the Fairphone 6 and its protective case.
I’m a huge fan of colors and I believe that the accessories we use should reflect our personality and be pleasing to look at. For me, color is a form of communication.
I really wanted a case for my Fairphone, but unfortunately, I didn’t find a color in the official store that truly spoke to me. I liked the white one, but after reading here on the forum that it tends to yellow or stain quickly, I decided to go with a DIY solution: I bought the white case and dyed it myself.
If you’re feeling inspired, here’s how I did it!
Materials:
1x White Fairphone 6 case
1x Rit DyeMore for Synthetics (Sandstone)
1x Stainless steel pot
1x Thermometer
Water
Dish soap
The Process:
1. Preparation: I washed the case thoroughly with dish soap to make sure it was free of any oils or dirt.
2. Heating: I heated about 1.5 liters of water in a stainless steel pot to 80°C.
3. The Bath: Once it reached 80°C, I added a teaspoon of dish soap (to help the dye spread evenly) and started with a small amount of dye before submerging the case.
4. Consistency: I kept the case moving constantly with a pair of tongs, making sure it didn’t sit at the bottom of the pot.
5. Dyeing: I gradually increased the temperature to 93°C. During the process, I added more dye two more times to reach my desired shade. In total, the case was in the water for 30 minutes.
6. Finishing: After reaching the perfect shade, I rinsed it under cold running water, wiped it dry, and let it rest for an hour before putting it on the phone.
Check out the results in the pictures! :slight_smile:
I hope this helps someone who wants to personalize their device!
Keep in mind:
The case was brand new and unused. I dyed it right after unboxing to ensure the most even color absorption possible.
Important: Compatibility check
Keep in mind that this only works on certain materials. While it was perfect for the Fairphone’s case, we also tested it on a standard Samsung silicone case, and it barely took any color, it only turned a faint yellowish tint after 30 minutes.
Before you start, make sure your case is made of a dyeable plastic (like the official FP6 case)!
A note on the dye (based on Rit’s guidelines):
If you are worried about the dye rubbing off or damaging the material, don’t be! Unlike regular paint, Rit DyeMore for Synthetics is a non-toxic, industrial-grade dye that works by penetrating the surface of the plastic on a molecular level.
Stability: Once the case is rinsed and dried, the color is locked in. It won’t rub off on your hands, clothes, or the phone itself.
Safety: It’s a liquid concentrate that is safe to use in your kitchen (as long as you use a stainless steel pot), making it the perfect choice for a sustainable DIY project like this.
Impressive result! Almost like a leather look. Or mahogany.
One thing piques my curiosity: Your photos 4, 5 and 6 show two clearly defined different shades of brown. Did this come by itself (different materials in the case that result in different hues) or did you apply a trick? The separation is so obvious that it is hard to think this was accidental.
:thinking: :wink:
Looking pretty good !! :face_with_crossed_out_eyes:
Actually, it seems like Fairphone used different types of materials for this case, which reacted differently to the dye.
The outer shell absorbed the color beautifully, but the frame and the inside seem to be made of a different polymer. Luckily, the tolerances and the fit are so precise that the dye followed the seam lines perfectly, creating a clean, professional two-tone look.
The inside of the case is likely a third type of material because it didn’t take any color at all. You can see how it looks inside here:
Thank you so much, I share your opinion, I quite like how it turned out.:grin:
Very beautiful :heart_eyes:
And thanks for sharing elaborately!
I’m glad you like it. Happy to share.:smiling_face:
