I have big problems with my left side of the touch screen. I can´t use the last 10% of the left side.
It jumps to left edge of the display. See picture.
I cleaned all the display contacts. But nothing help.
It happens after software update. But I´m not sure that this is the problem?
The phone is now 1,5 years old.
Display problems and the case is falling apart
Both seem hardware defects (from your description) and are usually covered by warranty (for the first two years). See the troubleshooter (for the display “the touch function is defective”; the case issue is easier to find) for which details to supply to Fairphone support so they can help you.
