My Fairphone 3 is fallen down and as result the Display has Detached not the normal way.
Is it possible to fix this ?
The Display is not broken und working fine
I’m not sure what I see.
is the whole screen and LCD come off but is still connected by a cable,
if so as the only replacement is the whole screen module you can try glueing them together, and to do that I would use clear nail varnish.
