When I use the shortcut to open the camera from the lock screen (by quickly pressing the power button twice) a loud vibration happens. How can I turn it off? I have looked through the settings but I can only find the option to turn the shortcut off.
I guess that’s not possible until you are either in silent or battery saving mode.
But there isn’t really a need for this function since you can just swipe to the middle of the screen from the bottom right corner to activate the camera, or when the phone is already unlocked you can long press the camera button.
Edit: Oh, by the way: sorry that nobody answered you yet, this doesn’t happen usually.
