Disable USB connection sound
My FP4/Android12 has USB debugging enabled.
When I connect it to my computer via a USB-C cable, it makes an annoying loud “kling-a-ling” sound.
How can I disable that?
Maybe this setting helps?
Einstellung->Töne&Vibration
Perfect, that does it. Thanks!
It was not obvious.
