Hi, my phone goes into silent vibration after each call. Is there a way for it to automatically go to regular ringer sound mode? (I have disabled all do not disturb settings, but i see DND turns on when a call is ongoing)
Don’t know about this one, but sometimes funny things happening while calling may be solved by calibrating the proximity sensor (Settings > Maintenance).
Thank you for the suggestion, but it didn’t work unfortunately.
Is your OS up to date?
I think i solved it. I have an app to lock the alarm volume, and disabling that apps access to do not disturb seems to have solved the problem. Thank you for the suggestion.
