I am now completely frustrated. After many hours and with win 10 installed /e/ and locked bootloader again but after several reboot-attempts e did not start. I am now a prisoner in recovery mode and this with locked bootloader. So it seems I cannot install any OS or TWRP. Hope that I did not brick my phone!
Could it help to go back to stock ROM due to the locked bootloader and then if stock is installed unlock bootloader again and install any custom ROM?
Installing the stock Fairphone OS requires unlocking the bootloader, too.
Can you unlock it in the current state?
For a while fastboot oem 8901_unlock
could do it without the code procedure, but it seems this was removed …
Yes, thanks. After restart pressing down and power it now stats DEVICE STATE-unlocked.
But now: adb devices says: list of devices attached instead of No. of device.
Maybe you forgot to post something, but with Volume-Down and Power you end up in fastboot mode and adb is the wrong tool for fastboot mode.
From fastboot mode I got following message after first command:
C:\Program Files (x86)\Minimal ADB and Fastboot>fastboot -w
wiping userdata…
CreateProcess failed: Das System kann die angegebene Datei nicht finden. (2)
error: Cannot generate image for userdata
should I try to continue with next commands:
fastboot flash system_a system.img -S 522239K
etc?
or better try to flash any recovery like lineage recovery or TWRP.
If lineage works I would stay there.
That sounds as if the “Minimal ADB and Fastboot” installation does not contain the mke2fs
binary.
IIRC nowadays the suggestion is to just install the latest official “platform-tools” package from Google.
The latest tools from Google are also the way to go on Windows.
Thanks for your help.
After 2 days hard work /e/ Android 10 is running!!!
I have to admit that the big problems are not caused by /e/ software directly but by 3 reasons:
Tried to flash with Linux. Currently there seems to be a bug within adb/fastboot. Use Windows until further notice. Hope it will run in future under Linux.
Did not use the latest platform-tools. Even under Win Minimal ADB and Fastboot is very old and not suitable. Always download latest platform-tools (do not use Minimal ADB and Fastboot) as adviced by Ingo and AnotherElk.
I made a very severe mistake and continued installation after receiving the info:
" fastboot -w
wiping userdata…
error: Cannot generate image for userdata"
All further commands work (that is the problem!!!) and also lock bootloader but then the system does not start.
This resulted in a completely unusable phone with locked bootloader and I had the impression that it is bricked. With your help I unlocked bootloader again.
After 2 days “try and error” I found a solution by chance:
a) installed the new
lineage-16.0-20201116-recovery-FP3.img
This is a very effective and lightweight recovery. With this recovery is was possible to delete and format.
Then back to /e/ it was no problem under win 10 with latest platform-tools to execute commands :
fastboot -w and all other commands.
Hint: You should always copy and paste commands to avoid any typing errors.
I now belong to the happiest people of the world as my FP3 is working again
I didn’t have problem to flash /e/ Q with linux (opensuse Leap 15.2) and in the /e/ forum I’m pretty sure there were others who were able to successfully flash it with linux.
True, if someone has access to both OS and it doesn’t work on one, it might be an idea to use the other.
But I wouldn’t advice against linux in general. Otherwise people could refrain from trying to flash /e/ when they simply have no windows machine around.
Glad you got it to work.
The install instructions say …
“Requirements
2. Make sure your computer has working adb
and fastboot
. Setup instructions can be found here.
Please ensure you follow the instructions for adb and Fastboot setup exactly as given in the previous step to avoid unexpected issues during device setup.”
/e/ added the additional warning for a reason (which you encountered yourself) … https://community.e.foundation/t/add-a-warning-to-e-install-instructions-to-avoid-fastboot-w-failing/15627.
If the instructions are really being followed in this case, 3. doesn’t happen, and 1. and 2. don’t become a problem.
Fully agree. I have been using Linux for 20 years now and I am very happy with it. Maybe there was something wrong with my drivers.
Continue using Linux!!!
Happy End!
Fairphone runs with /e/ extremely well!!
Thanks for the help!
My promise for the future: Will read all instructions carefully!
