Hi everybody,
I’m configuring my new Fairphone 3 to use Data and Hotspot.
My mobile networks provide two different APN settings for Mobile Data and for Hotspot. However, I notice that in the Fariphone settings, I can just “select” one of the many possible APNs. How to say
It is possible to set two APN.
But each time you want to change from Mobile Data to Hotspot and back you have to manually choose the correct APN.
In Settings
Mobile Network
choose SIM 1 or SIM 2
tap on Advanced
tap on Acces point names
tap on the + after the name APNs to enter a new APN
Here you can choose which APN you want to choose.
I am not sure if I understand your issue correctly. Mobile data is consumed via the mobile network and therefore needs an APN setting. Hotspot on the other hand uses Wi-Fi technology and does not need an APN.
