Android Application Package
Android application package is a container format for software (apps) for Android smartphones. It has the file extension “.apk”. APK-files can be downloaded directly to the Fairphone and installed by checking “Unknown Sources” in Settings > Security.
For a more extensive howto check the #installanyapp guide.
