Deleted Button on home display
I deleted by misstake the button who brings me from the home display slides to the slides with the overwiev over all apps. How do i get the button back?
Thanks for your help.
A lot of people already have had this problem. Use the search function in the forum (little magnifying glass above) and I am sure you find a solution. :slight_smile: (If not, come back to me!)
Thanks for explaining the search function. Seems very similar to what i’ve done before i opened a new topic.
I didn’t found any helpfull stuff after searching for “home display”, “deleted button”, deletet…and so on.
It would be great if you could help me with a link.
It’s called the “recent apps widget”:
Thanks alot for your help Jerry. Problem solved!
cheers
Glad you got this working.
This topic is now closed. New replies are no longer allowed.
