Customisable lockscreen on Android 14
The release notes for Android 14 say it has a (slightly) customisable lockscreen - change the look of the clock, alter what the shortcut buttons do (e.g. make one the camera).
This is meant to be activated by long pressing the lock screen, but this isn’t working on my Fairphone 5.
Is it for anyone else? Or is there some other way of getting to it?
Does not work for me either. Is it stated somewhere that you’d activate by long press or is that the default A14 behaviour?
You can customize the lock screen in the settings, “Wallpaper and style”, and check the “more lockscreen options” at the bottom
Please follow-the discussion here and ask feedback from Fairphone by contacting support.
