Ctrl + Alt + Del on Bluetooth keyboard reboots FP
When a Bluetooth keyboard is connected, pressing Ctrl + Alt + Del reboots the phone - without any confirmation. Is this a feature? Can it be turned off?
This is kind of annoying because switching the Bluetooth keyboard between FP and PC and having to log in on the PC results in the phone rebooting if you (or the keyboard) misses the switching.
Any fix or workaround highly appreciated.
Nice! I didn’t know that Android also has this nice Ctrl-Alt-Del-Feature (FYI, on Desktop-Linux, Ctrl-Alt-Back/Del normally kills the X-Server) :wink:.
But unfortunately, I fear there is no way to change this, since it should be included inside the kernel (I googled it and it seems to be standard behaviour on android).
