Hi there,
my last phone (Moto Z3 Play) works fine with USB3-Connetion to PC.
So I think, my FP3 uses USB-C, so I can also use USB3, but nothing happens: No Sound from the PC for Connection, no aktivitiy in the Explorer. I`ve updated the ADB-Driver, reboot the PC, reboot the Phone, nothing.
Then I change the connetion to USB2 and: It works.
Maybe that is a fault on my PC…
AFAIK the FP3 doesn’t have USB3, only USB2.
Check the official specs:
https://shop.fairphone.com/en/fairphone-3
- USB 2.0 support
That’s true, there is no USB 3.0 in the FP3. If you look into the USB-C connector you will see that the pins for USB 3.0 are missing.
Where did you change this connection type? I am assuming that this is in some program on your computer. PCs should automatically detect it, there should not be any need to change an option for USB 2/3.
