Checking in with Facebook doesn't work
When i try to (FB)check in on a location with my FP2 i get a list of nearby locations but when i click one off them i only can “edit” that location. I cannot select it. As far as i can see the FB settings are identical with those on my FP1m where it works as it should. Am i missing a setting???
I do not use Facebook, but maybe this could also be a Privacy Impact setting issue, see:
https://forum.fairphone.com/t/misbehaving-apps/11721?source_topic_id=11817
It is just a guess, but with some of my apps started working properly after unchecking the Privacy Impact (Settings->Sound & notification-> Privacy Impact) checkbox.
This indeed solves my problem, thanx
