hello,
It is not for Fairphone.
Not to throw my GPS Garmin nĂĽvi 1490 !!
Map update is no longer possible, I can not buy
Who has a solution? thank you
François
hello,
François
OsmAnd+ on Fairphone, worldwide, offline, always up-to-date…
Only issue is the GPS initial convergence is really slow. After this, turn-by-turn driving is perfectly OK.
en français:
Tu dis poser une question qui n’a rien à voir avec le Fairphone, mais… avec ton Fairphone tu peux installer l’application OsmAnd+ (gratuite et open-source sur F-Droid); ensuite tu as accès à toute la cartographie Openstreetmap (hors ligne, après bien sûr le premier téléchargement).
Mon expérience quasi quotidienne est que le guidage vocal fonctionne parfaitement, dans un français raisonnable (toutes les liaisons ne sont pas parfaites), le seul point négatif étant que le GPS du téléphone (en tout cas du mien) converge TRES lentement au démarrage. Après, ça marche très bien.
En voiture, penser à mettre un adaptateur allume-cigare pour les trajets de plus d’une demie-heure…
It should be possible to install free maps from OpenStreetmap on your device.
I’m quite late…, but I want to share that wonderful service each Garmin GPS user might know to update his maps database: http://garmin.openstreetmap.nl/. It requires your Garmin GPS to have an external memory card, such as microSD™.
While planning a trip by road from South West of France to Eastern EU: I realized that Garmin maps expensive updates only include few countries. A DuckDuckGo overlook brought me to http://garmin.openstreetmap.nl/.
I uploaded the map, made from the tiles I’d selected, with the link provided by the website, uploaded the map file to the microSD™, did the boot from the settings: it worked, all my statics tests to navigate were fine. Once on the road, my GPS did the job perfectly bringing me on the front door of my friends house. Once back to France I donate via PayPal to help such a great service to be maintained.
Je suis en retard…, mais je souhaite partager un service que chaque utilisateur d’un GPS Garmin devrait connaître pour mettre à jour ses fonds de cartes: http://garmin.openstreetmap.nl/. Ce service nécessite d’avoir un GPS Garmin avec une carte mémoire externe du type microSD™.
Alors que je prévoyais un voyage par la route depuis le sud-ouest de la France jusqu’en Europe de l’Est: j’ai réalisé que Garmin ne proposait que quelques pays dans les mises à jours, très chères, des cartes. Une recherche via DuckDuckGo m’amena à http://garmin.openstreetmap.nl/.
J’ai chargé la carte compilée, à partir des tuiles que j’avais sélectionnées, grâce au lien fourni par le site web, puis installé la carte sur la microSD™ de mon GPS Garmin, je l’ai bootée depuis le menu du système : ça marchait, mes tests statiques fonctionnaient. Une fois sur la route, mon GPS fit le boulot parfaitement jusqu’à m’amener sur le pas de la porte de la maison de mes amis. De retour en France, je me suis empressé de faire un don via PayPal pour soutenir ce super projet !
