Car phone holder for FP4
Can anyone recommend a UK phone holder that will attach to a car windscreen or dashboard and that will hold a FP4 plus case, please?
I bought a standard one and it is not wide or deep enough, especially when the case is added, so the phone can fall out while I’m driving.
A previous discussion recommended one that fits on the air vent but I need the screen or dashboard fixing.
Any recommendations welcome.
hi @Isabel2
which case do you use?
I purchased my car phone holder in a high street shop. It was only marginally more expensive than similar products on the big A and you can try before you buy. Good luck finding what you’re looking for.
I use this one, the FP5 fits with a case (not the official one)
https://www.amazon.de/gp/aw/d/B09G6GZR84?psc=1&ref=ppx_pop_mob_b_asin_title
I have the Fairphone case. It’s quite chunky!
Hi @Isabel2.
i think you’re are just a bit unlucky with your phone holder.
i expect most holders for bigger phones will work fine.
i have the FP5 and Tudia case. i think it will be bigger in each direction as your FP4 with case, please correct me if I’m wrong.
I’m using:
Baseus Gravity Dashboard
sorry not a UK link:
but hopefully still helpful for you, finding the right one that fits you?
and on the bike:
GUB Pro 2
https://amzn.eu/d/1gFr1Nw
really happy with both.
with the Baseus Gravity, i need to wiggle the phone sometimes a little bit to get it in properly, and not as advertised just throw it in from a distance (its a bit tight), it never slipped out even when i was driving challenging unpaved roads.
