When I “wake up” my FP2 it is taking 2-3 seconds for the screen to stop being black (much longer than normal. Then the touch screen doesn’t work. After a minute or two of trying to unlock, the screen will come on at a normal speed, and the touchscreen will work.
I’ve tried taking the battery out, but the problem returns minutes later. I’ve been having this issue for several days now. My Fairphone 2 is a few years old, but the problem is new. It’s similar to this problem: Fairphone 2 touchscreen suddenly freezes
I suspect this is a software problem, because it correlates with the screen taking a long time to come on. Can anyone help?
I’m on FairphoneOS should be 19.05.3. The problem is intermittent, but has occurred frequently enough in the last few days that I’m concerned. I have reset the phone by removing the battery 2 or 3 times in the last few days, attempting to get the screen working.
I’m not familiar with the bugtracker, I’m afraid, so I don’t know if this is a known issue or not.
