Can't downloads blobs for Android 13 / FP3
Following the build instructions from here.
basically tells me to execute:
vendor/fairphone/tools/bin/get_blobs.py --device FP3 --build-id 6.A.019 --blobs-dir /tmp/test
which tries to download
https://storage.googleapis.com/fairphone-updates/fp3/b70c2cfc-09c1-4959-a82e-3428370f25d1/FP3-6.A.019-blobs.tgz
This does not exist.
Can you make the blobs available anywhere?
I think you’ll have to contactsupport for asking FP to make the blobs available somewhere.
Either that, or a permission problem exists on Fairphone’s side (I opened the link in Firefox):
<Error>
<Code>AccessDenied</Code>
<Message>Access denied.</Message>
<Details>
Anonymous caller does not have storage.objects.get access to the Google Cloud Storage object. Permission 'storage.objects.get' denied on resource (or it may not exist).
</Details>
</Error>
Support won’t be able to help you with this, or at least not very quickly. Let me poke a few shoulders and see if I can get you an answer from the relevant team.
The file should be up now. Try again and let me know if you encounter more problems.
Thanks, builds fine.
Can’t say if the build works, I will try in the next weeks when theres time.
