Cannot uninstall Threema from FP2 running (latest) FPOOS 23
After moving to an FP4 with /e/OS (fine!), I try to uninstall Threema (non-system, messenger) from my old FP2, which runs the latest FP Open OS (which is so buggy that I am forced to the FP4 :frowning:
The uninstall fails with the simple statement “packet installer was terminated” (well, in German: “Paketinstallation wurde beendet”), whether it is started from the launcher, from Aurora, after reboot or after terminating the packet installer.
Is there anything I can look up to find and fix the cause of the failure?
(This is needed because every time I start the FP2, Threema connects to its server, meaning I get a warning on the FP4 that “somebody” used my Threema account on another device. )
Danke & Grüße von
nobi
You don’t need to uninstall Threema, just delete your Threema-ID from the old phone.
…or you just factory reset your FP2? This would “automatically” trash the old Threema installation together with everything else. And after a factory reset the FP2 might appear to be less buggy again?
