Can i use the FP2 usb-connection with FP4?
I have an FP2 and am ordering an FP4. Is it necessary to also order a new USB-cable? Or can I use my old micro-USB plug in the USB-C receptacle?
No, that doesn’t fit at all.
You can use the cable with an adapter, but not otherwise.
You may miss out on some Rapid Charging options.
The power and data transfer levels are lower, and you may be fine with an adapter but to be safe you can buy an IF certified USB-C
OK, clear. Thanks for the quick replies!
