I’ve recently bought a second-hand FF1 and my internet connection won’t work. (It worked yesterday). I’ve been trying to connect to Google Play Store and other apps and get a ‘No connection’. Facebook works though. It’s connected to my WiFi and the signal is apparently strong, so why don’t these other apps work?
It sounds like it’s a problem specific to the app.
I’m not particularly proficient in FP1 but there are some standard general responses in the case of a misbehaving app.
You can clear the cache or application data from the Settings (Settings > Applications > Google Play Store).
