The camera LED on my FP1 (batch 2) stopped working roughly after updating to 1.8.
It happens both with the flashlight and camera apps: no errors, just darkness
Anything I can try before ordering the spare part?
(e.g. a factory reset)
I don’t think it’s likely to be software related, but you could try a factory reset or a downgrade to v1.6 again.
That would be the way I’d try to find out if it was hardware.
Also, unless you’ve dropped it etc, it should be covered under warranty so I would speak to support directly first before ordering young own spare parts
do you have any updates regarding this topic here? I have the same problem since a couple of weeks. I might have to do with a drop ^^
Is there any spare part or a software solution?
I have no definitive proof for the cause or the fix of the malfunctioning LED.
The spare part is sold by FairPhone, but you would need to replace it using SMD soldering.
I did not have specific equipment not to damage the thin plastic, so decided not to proceed, but I would guess there are ways to do it successfully also with an ordinary solder and a suction pump with due patience and care.
If you have the skills to replace it, PM me and I’ll send you my spare part for free. It’s for the second batch, but seems identical to the one for the first.
On a side note, I must praise the robustness of the phone, because after I dropped it many times it is still aesthetically immaculate (save microscopic bumps on the white border) and works flawlessly (save the LED…).
Ciao @Enos, vedo che scrivi dall’Italia perciò ne approfitto per comunicare un po’ più velocemente.
Sto avendo problemi al flash e credo di non avere altre alternative se non sostituirlo. Purtroppo al momento non è disponibile tra gli articoli del sito. Hai ancora quello che avevi preso? A meno che ovviamente tu non l’abbia già utilizzato.
Fammi sapere
Luca*
