It’s not a bad feature, what makes it a problem is that the user cannot override this. So in case you’re at a party late at night with a low battery, suddenly you cannot take pictures anymore with a flash. I’ll ask FP support to add an option in the camera options to disable this because the battery saving is minimum but there is a loss of functionality. It should be a decision of the user in the end, what he/she values more and thinks helps with a low battery.
