Hi there,
is there a way to get the fully featured camera on CalyxOS? Also wide angle etc?
Please read the conversation above and see here
Just was reading ur tutorial for the camera hack and was wondering⌠U know u work for free to hack a phone to finish an badly done firmware? .
How do you install it as system app in system-priv?
Iâm trying to include it in my LOS build. However, I do not know how to move OCâs gradle setup to Android.{mk,bp}.
When I last tried it I added Open Camera as a Prebuild APK. See Prebuilt apk in Build | AOSP Rom Development | Aditya Telange
Donât think gradle can be included easily.
You can add it directly in the device tree git repo, i.e. create a folder device/fairphone/FP4/Opencamera with the APK and Android.mk. Also add a privapp-permissions file etc.
If you want to include the stock FP4 camera, you can just include the prebuilt APK via proprietary-files.txt
Thx. That did the trick.
wide angel is working now in iodèOS
at least in their opencamera fork. not sure if it is also working in gcam versions. have no FP4 to test ist
I bet the OpenCamera is installed as a system app, that would explain it. I doubt thereâs been any change made to the API recently.
Iâd love to see this in CalyxOS⌠seems like a non-/low-priority issue currently :-/.
yes, fixed with SYSTEM_CAMERA permissions
tried it some time ago but didnât work. weird only nowâŚ
they are using AOSP based default camera, also as system app
you just have to ask them if the want to implement it in their camera, should be possible, too, i think
The next CalyxOS update will include unlocked aux camera for all 3rd party apps. No need to mess with SYSTEM_CAMERA or anything
Is this something you can alter in source? I thought it was in precompiled proprietary blobs.
It is in proprietary blobs but with a little creativity you can bypass the check: https://review.lineageos.org/c/LineageOS/android_hardware_lineage_compat/+/344852
https://review.lineageos.org/c/LineageOS/android_device_fairphone_FP4/+/344881
Sounds great, looking forward to ne next release now :).
Man, Calyx is slowly winning me over with these bombshells
Just updated to the newest CalyxOS Beta and without any additional configuration got wide-angle support in GCam, just like that
Now letâs see when/if Fairphone manages to enable that officially for stock FPOS
I just wish it wasnât so laggy. whenever I switch to wide angle in the GCam I use, it feels like itâs got night mode permanently enabled.
I did have some lags in a darker environment, in a well lit room itâs about as responsive as the normal lense for me.
Youâre right, seems like some kind of low-light processing gets triggered, but the normal lense doesnât have the same issue in an almost dark room
Open Camera doesnât lag with wide-angle in low-light situations either, so this is likely a GCam issue. Hopefully it can be fixed by diving into the configs Iâll have a look.
And the wide angle camera is now also working in the manually installed stock FP4 camera in Pro mode opened via shortcut on CalyxOS. Just the default Photo mode is still crashing.
In the default CalyxOS camera app, are you able to switch to wide angle and if so, where? I only found the wide angle option in Gcam and stock cameraâŚ
