When calling, I have a too high minimum volume when using headsets (that is, the volume is too high even if I put it at a minimum) and a too low maximum volume when I am using it without headsets (the volume is too low even if I set it to the max). I’ve read that this was a known issue and it has been improved in the new version (1.3.6?) of the Fairphone OS.
What about Fairphone Open OS? Are you experiencing this issue? I didn’t notice any improvement since last update (now using 16.07.1).
Where did you get that from?
The latest version is 1.6.2, but there are no changes to the volume issues in the release notes. And since Open OS is based on Fairphone OS all issues from FPOS are also on FPoOS.
This topic was automatically closed 2 days after the last reply. New replies are no longer allowed.
