After I updated to the newest version the google calendar is not working properly. When I start it it takes ages to show the entries and when I use an external calendar app (e.g. business calendar 2) the app simply crashes whenever I try starting it.
Did someone else experience the same problem?
Are there ideas to fix the issue? Restarting and re-installing the calendar app as well as logging in and syncing the google account again didn’t help here.
What I can say is, the calendar can be really slow if it has to integrate a large number of past events. In my family we have been handling various calendars built around .ics files stored on a central host, for years now. Adding one such calendar on the phone, by means for instance of icsDroid (free/open on F-droid) results in an enormous delay while the calendar app is “integrating” it, and also some sporadic huge CPU spending, which I didn’t really manage to control up to now.
If you have a very large calendar file to ync, it may be that the cal app is just… thinking about it…
Yes, calendars can grow over time, and how often does one need to go back and check what happened last year? I use the Calendar Cleanup app (in the playstore) for deleting past entries. Smooth. Don’t know if it will solve @Tobias_Muller’s problem though.
There might be open source alternatives, but I haven’t searched for them.
I never had that problem before, even after re-installing the fairphone OS again. But with the new update it keep on behaving like that.
Hi @Tobias_Muller,
i have no issues with Google Calendar and 1.8.7. Is it possibly just a coincidence and not related to the update?
Good luck with solving that issue. Sounds really annoying.
I don’t have google apps so I don’t know much about it. But if you can make sure somehow that the calendar is still stored in the cloud you can try the following:
go to settings > apps > all > calendar and tap clear cache and clear data and then do the same with calendar storage and google calendar/storage (if that exists?).
