I don’t build it myself anymore, but as far as I can remember there were no adjustments from Android 5 to Android 6, either. There is a good chance that it will work with the instructions that are already there.
By the way: Fairphone doesn’t seem too eager with updating that page or updating the blobs. That’s one of the reasons I decided to go with pre-built images. But it is still good for learning, I guess
Thanks for that. You are right. It seems that it’s not straightforward. The instructions and blobs on the website are designed for Android 6. I had a look at the repository and can only find references to 18.04.1 (Android 6).
I’m going to try building 18.04.1 for the learning experience, but feels like a step back .
Thanks for that. I built Android 6 and it was fun . Now I’d like to build Android 7. I contacted Fairphone Support directly about updating the build instructions on https://code.fairphone.com/, but they redirected me back here to the forum saying that FPOOS was community built.
